automagp68's avatar
automagp68
15000 BTU AC troubleshooting or not?
Hey all, ill try and make this short and concise
MY wife and i have been rving for about 5 years. We have had pop ups, travel trailers and this year we stepped up to the plate for our first (what i consider) big trailer
Picked up a nice 2014 KZ 36 foot toy hauler 5th wheel
Sory folks after a $70k truck to tow with the voltage was out of the question or any of the other big names but the KZ we could afford and we liked it.
It does not have the second AC unit but does have the 15,000 BTU AC upgrade
Trailer is wired for 30 amp service
AC is a coleman mach
I picked up the trailer out of state so the dealer is NO help
On the way home with our new toy we spent a night in an RV park just for the road trip
AC seemed to work just fine and was nice and cold
Finally got home and went to transfer all of our stuff to our new trailer in the driveway.
The dealer told me the AC would run on a single 20 am standard house electrical socket as long as it was all you were using.
So i decided to plug her in and turn it on given the fact it was 99 degrees out today
The AC never got really cold. I took out the temp gun and it never really blew much below 75 degrees. It just was like a fan.
I took the grill off inside the trailer and made sure the filters were clean. The ducting was good with no leaks and not loosing any cold air. It all looked nice and fine as you would expect from a newer trailer
its a 2014
Went up on the roof, took the cover off, and cleaned out the condenser and looked at the caps. Everything looked in order will no sign of strangeness
Is it possible its not really turning on because its not on a real 30 amp service plug but just on an adapter to a regular 3 prong house outlet.
Any suggestions?
The wife is about to beat me for buying the "broken trailer "
and of course the dealer being out of state is absolutely no help
  • 99* outside and you get 75* air inside? That sounds pretty good. You can have any dealer check out the AC and get warranty work done if needed. BTW, a 2nd AC would make things a lot better.
