Kaeferpaul
Jun 13, 2023Explorer
opnspaces wrote:
You don't need to hook up to the truck, a battery and jumper cables is actually preferred for testing as it eliminates the truck from the equation.
Are the small boxes circuit breakers?
or possibly relays?
I would go with wa8yxm's suggestion of making a really long ground wire. Hook one end of the wire to the negative of the battery. Hook the other end to the negative clip of your test light. Hook the positive of the battery to the trailer wiring. Then go pull bulbs and use the test light to check the sockets for power.
They look like the one on the top.
I've actually done some of that. The problem is the entire belly has an aluminum skin so access to wiring is difficult.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
