RLS7201
Feb 11, 2014Explorer II
The monitor does supply power to the camera through the coax. The center lead is positive and the shield is negative. Those same two conductors carry the video signal to the monitor. If there is voltage at the back of the monitor, then check and see if there is voltage at the camera. It's possible the coax has a break in it.
Good luck
Richard
Good luck
Richard
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
