dougrainer
Jun 02, 2014Nomad
1998 Newmar DS. The odds are the LED lights are 120 volt. They have a Inverter about the size of a golf ball (Square cube) that is connected to the 12 volt wiring. yes, it should be ON all the time. I will bet someone has rewired the system. Access the lights and follow the wires from the lights and I will bet you see that Inverter cube. There are usually 3 or 4 of these Inverter cubes for all the dash lights. They are wire tied in the bundle behind the dash cluster. Doug
I should have clarified---The Lights have AC voltage but NOT 120 volts. The AC voltage this Inverter supplies is in the 8 to 10 volt AC range if I remember correctly.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
