DSteiner51
Jan 09, 2019Explorer
I had a Honda engine carberated that unless the gas was turned off the carb would allow gas to flow into the engine while going down bumpy roads. New engine with <10 hours, missed so bad it would hardly run while smoking horribly. I drained the crankcase and put new oil in, replaced the spark plug and the problem was solved.
Could this be a problem on an Onan too? Have you checked the oil level to see if it has risen?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
