- NoVa_RTExplorer
I have scoured the internet with no luck. Roadtrek is currently out of business so no relief there.
A new owner emerged from the receivership, Rapido SAS, a French company that produces the Westfalia RVs. They have announced plans to reopen Roadtrek soon, but it’s going to be a smaller operation with fewer employees. Not sure how knowledgeable the work force will be about the older Dodge models, but I think the latch may be similar to that used on more recent models. They are probably backlogged with inquiries that arose while they were in receivership, but you may eventually be able to get some info. Check the website. - DFordExplorerHave you tried https://www.azrvsalvage.com/
The Roadtrek website I linked to had onwer's manuals for your 2001 190 model. They're willing to build a new Roadtrek to your specs. They ought to be able to offer support. I'm sure the part is part of the Roadtrek package added to the barebones chassis Dodge provided. - randemarExplorerI have scoured the internet with no luck. Roadtrek is currently out of business so no relief there. I had the van in for service at a Dodge dealer and they said the part was no longer available. Here is Phoenix, the dealers and repair shops are back logged for 5 to 6 weeks. I found a semi retired RV mechanic to fix a water leak and he said he will have nothing to do with glass. I went to a van junk yard today and found a used latch. It appears the piece that connects the window to the latch body is held together buy some sort of pin. It does not want to be pushed out and I can't apply a lot of force because it is attached to the window. At this point I'm not sure if it is a Dodge dealer, Roadtrek dealer or a glass company issue. Very frustrating. Thanks for helping.
p.s. The philip screws are out. I screwed them into the door because there is a mounting place on the other side that would fall and disappear without being held in place. - DFordExplorerI was hoping another Roadtrek owner would jump in here with an answer for you. I've searched around without any luck. You can try contacting Roadtrek for some help/replacement or at least find a dealer near you: https://www.roadtrek.com/ You can download an owners manual there but there's noting on the window latches in it.
I'd try taking the phillips screws out to try to see more. I'm thinking you can unscrew the inside piece but can't figure out how you'd hold the outside piece while doing that. There's no sense taking the old on off till you can find a replacement. Then you'll be able to see how it's held together. - randemarExplorerHinge is bad and disconnected from rear door after removing three screws. Not obvious how to disconnect it from rear window and afraid to exhibit to much force and break window.
- DFordExplorerCan you post a picture or two?
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
