SuperDutyFiver
Nov 15, 2013Explorer
The Bargman #78 Series replacement light is a match.
If just the light socket is shot-you can gut the new fixture and replace into the old-that solves the paint issue-if you're adding more lights then you need to address the paint issue. Somewhere you should have a code for what paint your coach has on it-duplicolor has many close matches and I've been able to paint lights well enough to install without issue.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
