dougrainer
Jun 01, 2020Nomad
There are 2 large posts on the solenoid. One post is from the Battery(12 volt POS). The other is a short cable going to the pump motor. VERIFY you have the same 14 volts to the solenoid as at the battery. If so, you can use a short 6 gauge or larger battery cable to jump those 2 large posts. You do NOT have to activate from the inside touch panel switches. IF the PUMP motor runs, you motor is GOOD and that solenoid is bad. If the pump motor does not run, then the Motor is bad. Doug
