dyoungker
Dec 24, 2013Explorer
Ok just checked out some more stuff... I pulled iff the cover from the converter and was getting 9V when the disconnect was on. Zero volt when off. I then check the voltage behind the disconnect and was getting 12V when off and 9V when on. So I disabled the disconnect and as soon as I connect the wires going from the battery to the converter the voltage drops to 9V. I then go back and think I am having an issue with my battery so I hooked up jumper cables from my truck to the new battery on the trailer. I was then getting 14V at the battery and behind the disconnect. As soon as I make the connection to the converter it drop to 10V and still nothing on the trailer works.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
