Mike_Schriber's avatar
Jul 18, 2016
2006 Damon Daybreak dash air issue
I'm having a problem with my dash air that has me stumped. It blows hot all the time. I've replaced the ACME water valve in the past so I'm familiar with that part of the system. I just clamped off the hose and it still blows hot (not warm, hot). With the clamp removed I get some weird numbers... the hose on the input side is at something like 140 degrees and the hose going to the ACME Bubble Unit is somewhere around 80 degrees (all according to my IR no-contact thermometer). That's regardless of the servo setting.
I was thinking I might have two problems (maybe low refrigerant and a bad water valve) but what I'm seeing still doesn't make any sense.
Any ideas?
Thanks!
  • Ford or Workhorse chassis? Most Workhorse use this unit..
    http://densoheavyduty.com/hvac-systems
    click on download tab for manual.
  • Gjac's avatar
    Gjac
    Explorer III
    Do you see any leaks anywhere? There is a switch with wires attached to the top of the switch that turns the AC on and off. Look on top of that switch to see if it is wet or oily.
  • Is the compressor running? If not you're most likely low on refrigerant. The water valve only stops the engine coolant from going through the heater core. Sounds like that is working given those temperatures.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
