map40
Aug 23, 2019Explorer
pnichols wrote:
As a side note: I never operate our motorhome's V10 at WOT. I climb grades with Tow/Haul mode engaged and then push the gas pedal down until the tachometer reads no higher than 4000 RPM. Whatever gear and MPH speed results is what it is and I hold at that until the grade is over. I could tap more V10 horsepower by using WOT but why push it, even though the V10 can "take it".
BTW, given our RV'ing style of often being way out there driving or camping in the Western U.S., chassis reliability is the our highest priority -> way above floorplan, number of batteries, number of solar panels, tank sizes, number of slide outs, type of refrigerator, number of televisions, size of shower, comfort of cab seats, etc..
Power curve of the V10 peaks between 3200 and 4200. You can get more power reving it higher but you will be consuming more fuel. Your approach is the most conservative from the point of view of fuel consumption and powertrain lifespan conservation
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
