springdalejk's avatar
springdalejk
2008 Springdale power issues
Hello RV net,
It's my first time posting here, I hope to frequent this forum in the future!
I have an issue with my 2008 Keystone Springdale (291RK SSR) regarding power.
I'll try to keep this short and sweet:
My wife and I (and cat) have lived in this trailer for over a year, plugged into 110v (using a 110v to 30a adapter) on the side of a house, running everything with only occasional power issues
Yesterday (over 100 degrees!) our AC unit was having one heck of a time keeping up with everything. We decided it would be a good time to finally switch over to our 30 amp connection, which was done on a good outlet with a single 30a cable to the trailer.
After doing this, initially, none of our power was working.
We flipped the breakers and checked the fuses (inside, on a WFCO 8955 series power center) and issues persisted
We tried switching back to our previous connection, same issue.
We can verify that both connections cause the same issue, so we think the issue is with the trailer. This was confirmed with my electrician friend who checked that everything had power.
After talking to a RV repair shop over the phone, we discovered two things: our trailer NEEDS to be plugged into the RV battery (they used the metaphor of it being a cushion for the RV power), and that the power supply in the power center is fried.
I ordered a new power supply, but plugging in a good battery, and using trickle charging, allows my lights and the AC fan to turn on, but the AC cooling will not kick in AND if I plug into any outlet with a surge protector with an internet modem plugged into it, this will flip the breakers of the MAIN and COM.
As of this point, I'm excited that the lights work, the fridge works (although I spoiled all my food), and the fan on the ac unit works. But I need that AC to blow cold air, I can hear it making a low rumbling noise like it's trying to turn on the cool element but it can't do it.
To any one who reads this, thank you so much for your time. I'm exhausted, been working on this for the past 24 hours and only slept about 3 hours last night up trying to figure it out. I'm sure I didn't write this perfectly, please let me know what I can clarify for any assistance.
Thank you kindly.
  • wa8yxm wrote:
    First there is no such thing as a 110 to 30 adapter. 30 amps is 110-120 volts.
    What you were using was, depending on your point of view a 30-15 amp adapter or a 15-30. BOth ends are the same voltage 120.
    Now, the outlet you plugged into.. Was that for a Dryer, or some power tool originally>
    If so it was likely a 240 volt outlet and you fried everything.
    Oops. To clarify, we went from a 110v outlet plug, to an adapter that our 30 amp prong coming out of the trailer could connect to. This was given to us (my wife and I) from the initial owner who used it to plug the trailer into a standard wall outlet.
    I'm thinking that you're right about the outlet we plugged into with this new cable, it is a power tool outlet, but it might be sending out 240 volts... Can this be converted to the proper voltage?
  • Please verify you have 120 vac in the RV and 12.6 to 13.8 vdc on the battery.
  • Whoa. Minefield.
    You "operated" your entire unit A/C included (occasionally) off of a 15-amp 120vac receptacle? For a year?
    Guesswork ain't gonna cut it.
    You have got to use a handheld voltmeter and trace down where the power entering the rig "runs into a snag".
    It is quite probable that low voltage has damaged various electrical systems and parts. note "probable" different from "possible"
    What is the limit of your electrical troubleshooting expertise? What electrical testing instruments and repair tools do you have at your disposal?
    Providing comprehensive diagnostic technique to someone not able to utilize it is an exercise in futility.
    So starting with those basic questions...
  • I can't explain why things quit, but I can offer that it sounds like your a/c isn't getting enough voltage to start the compressor. Check your voltage at the coach.
    I don't follow this. What is "our" 30a connection?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
Having RV issues? Connect with others who have been in your shoes.24,259 PostsLatest Activity: Jun 01, 2025
