Calkidd's avatar
Calkidd
220 Volt mishap
I went to plug in my RV inside my parents shop my dad had wired. The outlet is a 220 volts with three prongs. Something similar you would plug in a welder or compressor. I used the 30 amp RV receptacle adapter and plug in the trailer. The trailer is set up for 50 amp service also.
I think I screwed something up. When I plugged it in the transfer switch began to buzz really loud. I quickly unplugged it and plugged back in the 15 amp 110 volt plug.
I was told the 30 amp side of the RV is NOT 220 unlike the 50 amp service side.
Every other electrical appliance and plug still work, EXCEPT the frig. It will not work on AC, but will work on gas. There is power to the plug in the access panel. I took out the electrical board and none of the two tube type fuses were blown nor did I see and evidence of a burnt electrical board.
Although I didn't see any evidence of damage does it sound like I fried the board?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
