MEXICOWANDERER
May 13, 2016Explorer
Hahahahahahahahahahahahahahahahahaha...
Your question made my day. Been a sore point since Xylophone Tonkatoy purchased Trace*. You need to set the length of time spent at 14.8 as well.
Take a look at the MEGAWATT manual charger and set the voltage to 14.8. Use an INTERMATIC 4-hour spring wound timer to adjust time. The Mega WILL equalize at 16.2 volts but at not more than 20 amps max. Get the 36 amp model. I use multiple 36 amp Megawatts rather than charge incorrectly.
An old old TRACE 2500SB inverter charger is the best battery charging device ever built. good luck finding one.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
