toprudder
Apr 20, 2005Explorer
what if the generators hot wire comes in contact with the rv's metal framework when you are driving on the road? ,,are the tires enough to act as a ground?
I would think (and hope) that this would cause a fault and trip the current breaker. Neutral and Ground should be tied together, so if the hot contacts the RV frame (which should be connected to the generator ground) then a short-circuit situation should exist.
Rubber is non-conductive. However, I've heard that the tire manufacturers put something in the compound that adds a very small amount of conductivity to reduce static buildup on the car. I don't know if this is true, I've never checked. It only has to be several megaohms to work -- but this certainly is not enough conductivity to ground the vehicle to prevent electrical shock.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
