kilgtfish
Apr 27, 2005Explorer
I am tickled with my Power-pro generator. I just used a 50 amp to 30 amp converter pigtail....it has the 4 prong male 50 amp plug on one end and a female 3 prong RV plug on the other.....and I cut off the 4 prong plug and added the twist lock 220 plug that came with the genset. So I don't have any worries about not getting the maximum amps to the rv. The 220 plug is 30 amp. I also made a gen-turi which made the gen. even more quiet. I just followed the examples that others made in the forum. I used black plastic pipe from Lowes and a conduit ell. I spaced the ell with 1/2 " copper pipes placed at 120 degrees inside the black pipe....as someone else did in this forum. I just drilled a hole in the ell and the exhaust pipe of the gen. to pin the ell and allow for easy removal. The Power-pro exhaust pipe is only about 7/8 " so I used 1" conduit and 2" black pipe....it works perfectly. I don't feel that back pressure is a problem due to the small amount of exhaust from this engine. If your generator has a larger exhaust pipe of course you have to use larger pipe to your gen-turi.
Anyway....I am thrilled at the info I have gotten from all of the rv forum members. It really helps when problems are encountered to have this resource to call upon.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
