Jack_Shidemantl
May 12, 2005Explorer
I changed out the 120 V receptacle in my ELIM3000 the other day to use a more rugged unit as many here have done. I noticed when doing that the ground wire is connected to the frame of the generator. When I completed the swap out I started the generator and plugged in my line tester (you know the $3 units with 3 neon bulbs). It said I have an open ground. Obviously one side of the generator output is not grounded. Is it supposed to be like that? How would a GFCI breaker work in this situation? Are all generators wired like this?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
