Jack_Shidemantl
May 12, 2005Explorer
Yes I read about grounding on page 41 of these posts. I think I understand the floating ground issue. However a normal 120 V outlet has the neutral side connected to the same ground as the ground pin. we don't have that with these generators.
Of course when you switch to 240 V operation then you would not want that condition as both legs then need to float. So I'm just interested in knowing if both sides of the 120 floating above ground is ok? Doesn't sit right with me. Of course in 120 V mode I could always make an adapter to ground the neutral side. If you don't purposely ground the frame to a good earth ground is it better to let both legs of the 120 V float or what?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
