MrWizard
Jun 08, 2005Moderator
21 amps @ 120 v
NO 240 means all power should be available
it should run you A/C with no problems
just make sure your Hot water heater and your fridge are set ON propane
heating elements draw to much power..
I cant see the outlets in the picture
if it doesn't have a 30 amp twist lock, you should install one
OR
you should get an adapter that goes from dual 15amp recepitcle to 1 30 amp twist lock
this will keep you burning out the 15 amp outlets
OR
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Feb 01, 2025
