guy48065
Jun 16, 2005Explorer
In the schematic for the Wen PowerPro 3500:
http://www.y4hdesigns.com/images/PP3500schem.jpg
The Green/Yellow wire is shown only going from the chassis to the AC outlet(s). The little clip you describe sounds like what's sometimes used to connect a ground wire to the edge of an outlet box...no screws needed. Maybe it was pinched onto an exposed edge of the frame tubing or the panel where the breakers & outlets are mounted??
bobgay wrote:
TubaPete-The Green and Yellow wire is heavier than the green wire. Because of the type of fitting on the end of the green wire, it couldn't attach to the 110 volt receptacle. The green and yellow wire does have the type of connection that would fit on the 110 volt receptacle that now has nothing attached. Am I making sense?
Bob
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
