77charger
Jun 29, 2005Explorer
going to pick up a duro power tomorrow it appears to be the same as the powerwise3500,uses the juang dung motor,here are the specs they have in stock for 250 bucks they also have some 3000 watters 2800 continuos
1. 6.5HP Air Cooled OHV Engine
6.5HP, 196cc, Air Cooled, OHV, 4 stroke engine with Low oil shutoff.
2. Heavy Duty Steel Frame
Heavy Duty Steel Frame with four points fully isolated motor mounts for smooth & quiet
Operation.
3. Long 8-Hour Run Time
Long 8-Hour Run Time at full rated Output.
Long 9-Hour Run Time at 50% rated Output.
4. 3500W Surge
Max AC output: 3500W
Rated AC output: 3000W
5. 3.2 Gallon Fuel Tank With Gauge
All steel 3.2 gal. Fuel tank with ez-read gauge.
6. Decibel: 67 dBA
Super quiet muffler with spark arrestor reduces engine noise.
7. Full Power Panel
Full Power Panel with engine shutoff switch, voltmeter, circuit breaker & power outlets.
8. 2 Pole Single Phase Generator
2 fully protected 120V/60Hz power outlets.
Max Current 30A, PF: 1.0
9. Wheel /Handle Kit included
Two 5? Wheels & Handle Bar, operating instruction included.
Light weight: 100 lbs.
10. Idle control saves fuel
New tech throttle with idle control saves fuel & reduces noise.
11. Easily Run a variety of electric appliances & tools
Remote Areas, Construction sites, Outdoor Activites, Emergency Power.
12. One Year/1000 hr warranty for Residential
Three-Month/1000 hr Warranty for Commercial.
Operation.
4. 3500W Surge
6. Decibel: 67 dBA
7. Full Power Panel
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
