toprudder
Jul 04, 2005Explorer
VicT wrote:
As a result of the good customer service I got from Elim I now have a 1000 on the way and am looking forward to its lighter weight and smaller footprint. I was thinking It would run my small 800 microwave and my trailers furnace fan when needed (not simultaneously) but I see that may be pushing the 1000's limite. Any opinions on that.
The 1000w should be plenty for the furnace fan. Mine pulls 10 amps at 12-13v, should end up being less than 200w. However, this is powered through the converter, and the converter charges the battery. Depending on the size of your converter, the generator may or may not run the converter, but unless you have a converter with more than 60 amps output (about 900w) you should be ok.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
