ib516
Jul 07, 2005Explorer II
DODGETRUCK wrote:
Can someone tell me if the power maximizer adapter 15/30 from page 79 will work?
My gen lists 4500 watts but the ac trips the breaker. It has two 15a120v recep and a 30a/240v. no switch to select between. It has 2 breakers, 1 for each 15a/120v recep.
To get anything other than a general answer, you'd have to supply the make and model #. One of the electrical geniuses (I'm not one of them;)) on the forum will look up the wiring diagram and let you know.
As I understand it, If these adapters will help you at all depends on how the gen is wired internally.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
