cecilpwv
Aug 05, 2005Explorer
Throw the toggle over towards the 120V receptacle the full output of the generator will then be available there only.
Congratulations on your success, allpraisebob, and thanks for sharing the picute of the completed work with us. I am curious, though, why is full 120v output available only at the 20amp outlet. According to your schematic the 30amp outlet should be getting the same juice when the toggle is in throw position #2.
Also, if it is true, unless I am misunderstanding you, that only the 20amp outlet gets full current, then wouldn't you want to upgrade that outlet to a 30amp plug?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
