MrWizard
Aug 08, 2005Moderator
The gen starts like a champ, and I live at about 5000 feet.
Any ideas? Do I have a bad gen based on the voltage readings and inconsistent behavior?
Thanks in advance,
Desert
if the wiring checks out try adjusting the carb
i'm sure the stock settings are NOT for your altitude
wyatt-s
you tested the breaker
I agree it should be safe for the 'RE-wired' units
it's the stock units that are endanger of frying a winding by trying to draw too much current from only one primary because the breaker won't trip
Thanks in advance,
Desert
wyatt-s
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Feb 01, 2025
