Wyatt-S
Aug 08, 2005Explorer
nm_desert_rat said:
Desert,
There need to be two bridges at the gen head in order to wire in parallel. My schematic shows one bridge and the other bridge is placed by moving the red panel lead (since it is connected to the white panel lead in the sleeve) effectively placing two bridges. one across the red-brown gen leads and one across the blue- white gen leads. One brige will only allow one coil at any given time.
I re-wired explicitly per your drawing, and also using another suggestion, moving the red lead to the brown lead from the gen, thus eliminating the jumper. The gen voltmeter read ~220V before and ~110V after the mods, so I'm pretty confident that I did it right. I'll restore it to factory config and measure voltages again.
Desert,
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
