Emptyspaces
Aug 11, 2005Explorer
Hourmeter Installation:
Here is an example of installing a hourmeter. This one is on my ELM3000.
A view from behind:
RTV is a good way to secure wiring. Always use the non-corrosive kind.
Just poke around with your Voltmeter for somewhere that stays hot with the correct voltage. This is where I connected my 120VAC Hobbs Model 20001. Those that have 12VDC available would probably find a wider selection of available models. I picked mine up on EBay for $10.
I emailed the company to see if they had more available but have not received a reply. This particular one is rated 108-132VAC and .03 amps.
A view from behind:
