bassman1
Aug 19, 2005Explorer
JPearcy wrote:mrwizard I did read the users manual before I hooked the 4 prong plug up, you can split the 220 to 110 but maybe you split the power in doing so thanks
If you want 110 volts at 30 amps you might consider something like the ELM-3600SS which has a 220 volt 30 amp outlet that breaks into two 110 volt circuits, which could be used to backup a house for example, though this is still a small unit.
Look at the outlet shown on the ELM-3600SS at http://www.eliminatorusa.com/merchant2/merchant.mvc?Screen=PROD&Product_Code=E13&Category_Code=GGEN
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
