Clark_W__Griswo
Aug 24, 2005Explorer
professor95 wrote:
So, who makes the ELM3600SS? Is it JiangDong, or some other company?
The sound rating of 65db is a little lower than the 3000's 67 db. What are your observations on this?
The wheel kit is nice too.
It also appears from the specs on your web site that this unit falls into the same (undesirable) category of having the current available at 120 volts split between two separate outlets - a real negative for RV use.
When I saw this unit I thought the same thing: Wheel kit, a shade quieter, and about the same weight. I thought I might upgrade from the ELIM 3000.
With the 120 volt split, does this mean that it is different from the ELIM 3000 in the fact that the voltage is not split?
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
