BlackMax
Oct 12, 2005Explorer
I'd like to install a 4 prong 50 amp socket on the new Costco Nikota (3.5KW Generator 06044) that would eliminate all the adapters and dog bones. I know better than to assume I know what I'm doing, so if someone knowledgeable acquires one of these newer Costco versions of the Nokita, could you share your thoughts. Currently the trailer uses only one leg of the 50 amp plug, and I don't have plans to add the ac that requires that circuit. I do anticipate adding a box of some sort to accommodate the socket, but do not wish to degrade my ability to refit to duplex sockets for home emergency use. Also, permanent modifications may preclude me from returning the unit to Costco should it fail. With these units that's a real plus. Any input appreciated. Thanks in advance.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 09, 2025
