MrWizard
Oct 14, 2005Moderator
northshore wrote:
hoping that this isnt too far off topic, but has any one thought about wiring two 1200 watt Champion Generators together, simular to the way Honda does it with their 2000 watt generators
has been brought up, can't be done..the same way..
the honda's are "inverters" powered by a motor the syncing is in the electronics
the ''power pro's- elim-etc.." are standard mechanical generator heads , they would need to be physically aligned on the same shaft to be in phase/synced ( like the dynamo heads in a power dam run by a turbine )
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
