blazer8
Oct 15, 2005Explorer
I've been running my AC off an adapter through the 110/220 outlet on my 3500 PowerPro without problems. Are you saying that the standard 110 outlet only gets power from one coil while the 110/220 gets power from both? Why can't I run the AC on the regular 110 outlet without rewiring? Is it only getting half the amps? I've read almost this whole discussion and I am still not really clear how these things are wired inside. I'm not going to rewire it inside as the adapter works fine. I am just curious why it won't work and I haven't found the answer in this discussion. For now the adapter is o.k.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
