MrWizard
Oct 16, 2005Moderator
blazer8 wrote:
I've been running my AC off an adapter through the 110/220 outlet on my 3500 PowerPro without problems. Are you saying that the standard 110 outlet only gets power from one coil while the 110/220 gets power from both? Why can't I run the AC on the regular 110 outlet without rewiring? Is it only getting half the amps?.
yes
it takes both windings to get full/all the power
in the standard factory wired condition , the (2) windings are series
to give 230 volts , to the 230 outlet (3) wires ,
so the 115 recipiticle is only connected to (1) winding
the rewire [ connection changes ] give you 115 full power all the time and NO 230 volts.. ONLY 115
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Feb 01, 2025
