catalina30
Oct 18, 2005Explorer
MrWizard wrote:catalina30 wrote:MrWizard wrote:northshore wrote:
hoping that this isnt too far off topic, but has any one thought about wiring two 1200 watt Champion Generators together, simular to the way Honda does it with their 2000 watt generators
has been brought up, can't be done..the same way..
the honda's are "inverters" powered by a motor the syncing is in the electronics
the ''power pro's- elim-etc.." are standard mechanical generator heads , they would need to be physically aligned on the same shaft to be in phase/synced ( like the dynamo heads in a power dam run by a turbine )
Yes it can be done, but if done wrong you will know it in a big way. you can sync the wave form and then lock the two together ( the two generators will keep each other in sync once they are tied together). it can be done with light bulbs, but I will tell you that without training I would not. this is how in the grid they bring, or at least used to bring, a generator on line. doing it wrong is a sure way of getting everyones attention.
Kevin
The Right Lane
the power station dynamo's you are talking about are usually turbine driven ( by water from a dam or by steam ) this means slippage and possibliy stalling,
the dynamo being brought on line is only putting out a fraction of the power being used, and the EMF force it has to buck against ( slows the rotation / stalls it ) forcing it into mechanical sync with the rest of the power station
this is very difficult to accomplish " if not impossible " with (2) generators that are being directly driven by gas engines and NO belts or clutches
Didn't say it was easy, just said it could be done. I would take it that you have never been able to slow a 5.6hp gas motor down by putting a load on it? that is also the same thing. If one engine was set for a higher RPM it would take a lot of the load, but the generators would still sync after they were linked, gas or steam or turbine. we are just talking about size here.
Kevin
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
