blazer8
Nov 17, 2005Explorer
The 3500 is 220V because of two seperate 110V lines to the twistlock outlet. Assuming the 2200 is the same wiring setup, removing one wire from the 220 outlet will cut that voltage in half. In order to get 220 from that outlet you must be using a 4 prong male end. That would include two hot lines, one neutral line, and the ground.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 12, 2026
