TeamSlacker
May 25, 2006Explorer
over a year in service now with my powerwise with only the following problems.
new spark plug (was missing and starting very hard)
new recoil rope (see above lol)
(both above were not the real problem)
It started as just a slight miss while running, progressed to starting hard, to finally not starting at all. Checked all the normal, changed plug, unpluged the low oil sensor.. bam.. back to starting on first pull (and yes I did check oil level, and check it every time i fuel)
So Rich, you might want to try just disconnecting your oil sensor.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
