MrWizard
Jun 21, 2006Moderator
I think it's in another thread
all that is needed is to remove the recoil starter (3) bolts
and then remove the shroud (4) bolts
run a bead of ATV or similar adhesive around the edge of the plastic fan
you can remove the shaft nut and remove the fan to apply the ATV
OR do as I did and simply pull on the fan a little and squeeze/rub the ATV between the fan and the flywheel
allow to set overnight and if there is any rattleing of the fan it will disappear
several people have reported have a loose fan making a lot of racket and that this solved the problem
if i find the thread i will post the link
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
