MrWizard
Jul 07, 2006Moderator
CabanaBoy wrote:
For those of you with the Champion 'RV Ready' 46540, how often do have to add oil to it? I was able to verify that the low oil protection circuit works on mine. After 3 days of 95+ heat this 4th of July weekend, it did cut itself off. I know that you are to check each time you start it, but I ran it constantly for almost 70 hours except for fuel adds. On the morning of the 3rd day it shut down. I added about .2 liter of oil, and it started right up. Is it possible that oil is evaporating due to the high heat? I am REALLY hoping that I don't have a reject here. Also, it does not smoke - no visible signs of burning.
maybe once a week for me
I did the 5hr break in, then changed the oil, and have changed it once as a regular change at 50 hrs instead of the recommened 100 hrs
i changed the sparkplug to ngk 8bes, it made NO difference in the run speed or voltage
but the orginal plug was really dirty, BLACK & sootty
123 NO load
126 with converter
124-5 with microwave or A/C
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
