Tonka_Truck
Jul 18, 2006Explorer
Professor 95, Ugly Dwarf wrote: He was having problems with the power output. What was the outcome, bad circuit in his trailer?
I drilled a hole through a black iron round rebar stake and bolted (connected) a heavy guage wire to it for a ground stake. It's about an inch around and a couple of feet long. The wire is long enough to ground when in the pick-up bed also.
Question, on the xxx40 with the Voltage gage, is it accurate enough to tell if the Champion is putting out the right voltage?
Thanks,
Thanks,
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
