deshemar
Jul 22, 2006Explorer
MrWizard wrote:
these are all air cooled portable generators,
keep this in mine, when wiring a remote, the genny will NOT be inside a trailer compartment, it needs to be where there is suffiecent air circculation
the wire will have to reach the outside where the genny is
parallel to your shore cord ?
also the electric start will need a battery or wires to the exsisting batteries
also this affects the storage and use of the generator
Thanks for the heads up with your thoughts. My idea - don't know how it would work without having the genny yet - was to bring a remote switch to the inside of the TT through the same hole as the shore power cord (running with the shore cord approx same length)and make up some kind of quick connect plug pigtailed off the start switch of the genny. That way i could use the genny independent of the the TT if needed/wanted. Could use some input on this idea but also had a question if the Duro Power is OK or should I go for the champion - see lots of info on the champion but not much on the Duro Power
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
