hgarraway
Jul 25, 2006Explorer
SLCNewbRver,
You might try switching the fridge and/or h2o heater over to propane or off instead of the AC compressor when you run the MW. If the breaker is opening because the current demand is just above the limit it might work. Just a thought but probably too simple of a solution to fix it. Of course if you already run the fridge and h2o heater on propane while boondocking this won't help.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
