MrWizard
Jan 18, 2007Moderator
ok (1) 20 amp recpticle
(1) 30amp RV recpitcle, and (1) twist lock 220 volt plug
yes you can use the twist lock 14amps per leg
or use the 30 amp RV recp into a 4 way gang box and have 30 amps into the box from ONE feed, easier to USE than , trying to balance the load on the split box from the 220 feed
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
