jwitt
Jan 19, 2007Explorer
Hello, I have a safety question.
A few posts back, there was a mention of generators with the 240 v twist lock not having the ground terminal wired. My Champion "RV" has both the ground and the neutral of the 240v twist lock wired.
However,I have a second generator that has a 240v twist lock. The neutral leg of the receptacle is wired but the ground leg is not wired.
Do I need to tie the two (neutral and ground)together? I want to be able to use it for an emergency home generator, after I get a safety disconnect switch installed, of course.
I was surprised at the lack of the ground terminal not being wired.
I also bring this up for general info because if one was to plug in, say a 240v welder with three wires, ground, and the two 120v leads, it would lack a ground and a neutral connection. There may be other gen sets out there with the ground not being wired on the 240v twist lock..... Thanks, JIM
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
