MrWizard
Jan 19, 2007Moderator
Also, it wasn't explicitly stated in the manual, but does the 240120 switch on the control panel energize one or the other between the 240 or the RV outlet?
Finally, has anyone created a website or consolidated some useful instructions/pictures/diagrams for popular modifications to this Champion unit? Right now I'm wondering about building my own wheel kit and have seen references on prior pages to others who have done this, but not the actual description of how they did it.
yes it switches the outlets, there is NO 120 when in the 240 mode
AFAIK , no on the specific website
Do I need to tie the two (neutral and ground)together? I want to be able to use it for an emergency home generator, after I get a safety disconnect switch installed, of course.
I was surprised at the lack of the ground terminal not being wired.
NO do not wire the neutral and ground together, is will make the frame of the generator electrically HOT something you to NOT want
yes you can add a wire from the GRD lug of the 4 wire twist lock to the generator frame, DO NOT, wire the neutral & grd together
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
