bobandcat
Feb 03, 2007Explorer
I also have the 46535 Champion that I have rewired for full current draw on the 120 v circuit. I eliminated the 240 v circuit since I didn't have any need for it. If you want both, you need to install a switch like the 46540 model.
It has no problem running both my 15k AC unit and my microwave at the same time. I have measured the current draw for both to be 23 amps on my Montana. Just remember to run your refrigerator and hot water tank on GAS when you are using your generator. If you forget, your genset will protest the overload!
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
