JosephH1
Feb 05, 2007Explorer
I returned home from work Friday to find my new Champion C46540 sitting im my driveway. Upon opening it I found a lot of broken black plastic in the box. The air cleaner cover and the back cover on the control panel were broken. While I can see how the air box cover broke, I couldn't imagine how the back cover on the control panel broke. So I took a close look at the unit, and I discovered that the mount closest to the oil drain was bent to the point it contacted and chipped the engine case below the drain plug. Do you think this damage warrants a return of the unit or will it be OK to run? It will be a royal PIA to return as I do not have any retailers in my area and it was a Parts America purchase. Since the box and frame were in perfect condition, I think this had to be damaged during assembly.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
