bugdude
Apr 16, 2007Explorer
Oldfordman,
This is the one that I bought. I assume it will work.
Kevin.
Oldfordman wrote:
There is absolutely no reason not to as long as the hour meter uses 12V DC. The current draw from the meter won't even be noticed by the generator. The 12V output is there regardless of the other choice of outputs (120 or 240volts). Unless you are hooked to a battery, the 12V output is only there when the set is running.
Kevin.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
