MrWizard
Jun 18, 2007Moderator
yes thats full power to the duplex, the only problem is the breakers are NOT paralleled on the same paired legs of the windings when in the 120v mode, they are in the opposing legs used for the 240v mode
there was a discussion on this a couple of pages back, champion also did that on previous models, its something I dislike, BUT I know of no documented problems,
there is the possibly of one breaker tripping and the circuits still be hot, and NOT dead.. so if you have any power problems shut it down before checking the breakers.. but yes you can full 25 amp power from the duplex use a double dogbone adapter to RV plug, to avoid overheating one half of the duplex
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 24, 2025
