CCTAU
Jun 28, 2007Explorer
OK. Here is what I did to add an RV outlet to my PowerPro 3500 with selector switch. I used jpkiljan's (Thank you John) diagram. Took panel off. Removed plastic cover. Wired 10 ga black to hot (blue), Red to neutral (red) and green to ground. Ran my wires through same hole as existing wires. Located metal box on end with generator. Drilled holes and mounted. Terminated wires as diagram suggested. Used Grill paint to paint box black. Installed cover. Fired up genny. Will plug in pop-up tomorrow. No smoke or issues that I can see. Will follow up later. Sorry for the multiple pics. I couldn't figure out how to create a link for just these pics and not my others.
A big THANK YOU to jpkiljan and MrWizard.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
