freeatlast
Jun 29, 2007Explorer
magic43 wrote:
I ordered the Champ Saturday. UPS delivered it today. As per the instruction manual, I ran it 10 minutes W/O a load then plugged the Class C into it. It carried the AC fine. I then added the MW. Still had 122 VAC. I was impressed. I then unplugged from the Champ and into the 4KW Onan. Same voltage and not much less noise. The Champ was heavier than I expected.
This Fall when I load the Outfitter up and head to Colorado, I will leave the Honda EU2000 at home. It's a shame, but at 9000' the EU2000 has trouble carrying the MW or toaster.
I did the RTV job on the flywheel fan and will crank it again tomorrow.
Are there any other quick modifications that I need to do on the Champ?
I can't get over how so many of you have no trouble with the Champion Generator. While I like mine and it seems quiet enough...when I run *only* my AC, the voltage drops to below 100, the AC compressor rattles like crazy and the generator shakes like mad. I have blown 2 voltage regulators as well. I wish I knew why this is happening.
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 26, 2025
